    jcianciolo's Avatar
    jcianciolo is offline Junior Member
    Nov 2010
    9
    Gauges Not Working
    The gauges in my 1998 Jeep Cherokee Sport (4.0L) have not been working a for a few days. This happened once or twice before but was never an issue as the next time I started my car they worked fine. This time restarting the car does not seem to be doing the trick. Nothing on my control panel is working and my "airbag" red light is on.
    Any suggestions? Has anyone els had this problem?
    mscribe's Avatar
    mscribe is offline Junior Member
    Aug 2011
    bolivar, pa
    9
    Re: Gauges Not Working
    did you check the fuse? when i was playin with my radio it blew the fuse for the gauges idk how cause the radio fuse was ok but still if your fuse is bad the gauges wont work but im not sure about the air bag light mayb a bad fuse there too? good luck tho!!
    jcianciolo's Avatar
    Nov 2010
    9
    Quote Originally Posted by mscribe View Post
    THanks, but I fixed it. Took the dash apart and it was a simple as the plugs coming loose on the back of the gauge cluster. I re-seated the the plaugs and it has been working since.
    greg_arty's Avatar
    greg_arty is offline Junior Member
    Oct 2011
    11
    Im having a problem when I turn my headlights on and all the smaller gauges stop working. I turn the headlights off and they work perfectly.
    Asking for help please
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,513
    sounds like a possible ground issue
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
  1. Dash Gauges Not Working - Not Fuse
    By rgreenland in forum CJ YJ TJ and JK
    Last Post: 08-30-2010, 09:16 AM
  2. Gauges Not Working
    By tripz in forum CJ YJ TJ and JK
    Last Post: 06-25-2010, 02:47 PM
  3. gauges quit working?
    By Mxpx182lit in forum CJ YJ TJ and JK
    Last Post: 02-22-2005, 03:04 PM
  4. gauges
    By 1987-YJ in forum Items for Sale, Trade, or Give Away
  5. I have working YJ gauges now! Even the gas gauge!
    By Jeepr89 in forum General Chat
