Go Back   Jeepz.com > Technical Forums > Jeep Performance
  #21 (permalink)
Old 09-04-2007, 10:16 AM
TerryMason's Avatar
Administrator
Real Name: Terry Mason
Send a message via AIM to TerryMason
Re: how can i make power with a 4.2
have you upgraded the ignition yet?
http://www.jeepz.com/forum/showthread.php?t=16904 (TFI ignition upgrade)
It made a huge improvement in my 85 cj7, and was really cheap.
2005 Wrangler - 31" wheels, in-seat subwoofer, Huskey floormats, Wet Okole seatcovers, and a whole bunch of other money wasters.
View Public Profile Send a private message to %1$s Show TerryMason gallery TerryMason
  #22 (permalink)
Old 02-20-2008, 11:20 AM
Real Name: Rick Corson
To Mike B, This is what I did to my 4.2. Remove stock carb. intake and exhaust manifolds. Replace with 390cfm Holley carb. Model 4160 P/N 0-8007. Replace intake manifold with Offenhauser alum. intake P/N 6257-DP. Replace exhaust manifold with Pasesetter 6-2-1 header P/N 70-1128. This will solve some of your vacuum problems, give you more horsepower and better m.p.g. Parts for this project were about $900.00. The next phase of this project is going to be an ignition and coil upgrade probably M.S.D. These are a few things you might want to consider before you spend the big bucks on a new aluminum head. What the hell, swap the head too. Long live the 4.2.
View Public Profile Send a private message to %1$s Show chaos.258 gallery
  #23 (permalink)
Old 03-13-2008, 06:05 PM
Real Name: Rblue
GEAR'S/tera-low 4.3-1
View Public Profile Show RBLUE gallery
  #24 (permalink)
Old 04-21-2008, 07:48 PM
Send a message via ICQ to WV77CJ5 Send a message via AIM to WV77CJ5 Send a message via MSN to WV77CJ5 Send a message via Yahoo to WV77CJ5
So is the Weber 32/36 no good for a '77 CJ5 4.2L?? I am trying to upgrade mine and can't decide which carb to purchase and get a good value.
View Public Profile Send a private message to %1$s Show WV77CJ5 gallery
  #25 (permalink)
Old 07-02-2008, 10:49 AM
Member
Real Name: Frank
OK this is a good time to ask, I have a 78 Cj7, will that efi conversion work for me?, bay area CA, same smog checks you got in So-Cal. And is there a header avail for these jeeps, 258 I6?
View Public Profile Send a private message to %1$s Show franked gallery
  #26 (permalink)
Old 09-22-2008, 09:01 PM
ursman's Avatar
Member
Real Name: Mark
REALISTICALLY ... I would keep your 4.2L if it's not blowing smoke to bad from rings/valves, for budget reasons. A Weber is good so long as you aren't in a smog state (I don't know what Canada's smog laws are). If you don't have to worry about smog, then remove the AIR tubes/pump as applicable along with extraneous vac lines. For max carb power, i'd go with the Weber 38 as it has the largest venturis/secondaries. I went with the Weber for a few years but got tired of having to yank it all off when it came time for emissions testing. I saved up and got the Howell TBI which is probably the biggest single improvement you can do to any 4.2L. The driveability and power are unbeatable. I also went with Terry's advice on the TFI upgrade. If you're on a budget (like most of us!) This is a good step in the right direction. Also, any good muffler shop would be able to fab up some custom exhaust for a good canuck price!
'89 YJ, Howell TBI, 35"s, Lock'd & Load'd
Build it, Wheel it, Break it, Repeat
View Public Profile Send a private message to %1$s Show ursman gallery ursman
  #27 (permalink)
Old 09-23-2008, 11:15 PM
Member
Real Name: Frank
CHAOS.258 wrote:
Replace intake manifold with Offenhauser alum. intake P/N 6257-DP. Replace exhaust manifold with Pacesetter 6-2-1 header P/N 70-1128. This will solve some of your vacuum problems, give you more horsepower and better m.p.g. Parts for this project were about $900.00.
are these parts CARB certified for california emissions?
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
