Re: 2100/2150 swap via ebay
I bought this kit. The documentation is very thorough and this would probably be a good way to go if you dont have much experience with working on your engine, if you've swapped out a carb before, know what you're doing, and know which vacuum hoses go where, then you might be better off buying everything yourself.
What you're really paying for with that kit is the documentation, which I would definatley recommend if you're a newb.
As far as emissions, I dont live in a state with an inspection. I'd be careful about doing anything other than a certified MPI swap if you have to deal with that. I would guess, however, that the new carb runs cleaner than the carter in terms of a sniff test.
88YJ - 4.2L, MC 2100, Custom Cold Air Intake, DUI HEI, LiveWires, 2.5\" Lift
