10-10-2006, 12:30 PM
4.0 h.o swap
i have 97 jeep wrangler with a 2.5 in it and im buying a 4.0 ho for about 150 bucks and also getting the 5 spd tranny and transfer case out of another jeep cherokee and am planning to swap them into my jeep but was wondering what all i needed besides the computer, wirering harness. would i need motor mounts or will it fit directly in if ne one has any info on this swap please let me know
10-10-2006, 07:29 PM
Re: 4.0 h.o swap
You're going to have to change everything. The motor mounts are different, computer is different, tach is different, drive shafts are different, its gonna be just as tough of a job as it would be to put in any other motor. But... If you do go for it, we've got the answers
93 YJ 4.0
10-10-2006, 11:08 PM
Re: 4.0 h.o swap
thanks im definitly going for it but before i do i am trying to get the info i need to do it so i have all the parts to do it. if you have ne more info hit me up
10-11-2006, 05:18 PM
Moderator
Re: 4.0 h.o swap
You'll have to cut the motor mount perches from the frame and weld on new ones.
10-12-2006, 01:37 PM
Re: 4.0 h.o swap
well im buying a jeep cherokee for the motor trans and well everything for the swap would i be able to cut the mounts out of that of should i just buy new ones
10-12-2006, 02:14 PM
Moderator
Re: 4.0 h.o swap
You won't be able to use the XJ mounts, totally different design with the XJ unibody. You'll have to fab something or cut some from a 4.0L YJ. Don't know if there's anything on the market to buy and weld on.
10-16-2006, 11:37 AM
Re: 4.0 h.o swap
thanks for the info. i havent found out if the guy is still wanting to sel or not so i may no be able to do so just yet. but i will keep al the info in mind. imay just mod my motor for a few extra horses because it already runs good for a 4cyl. if you have any good info on horse pwr modes i can do let me know
10-16-2006, 12:21 PM
Moderator
Re: 4.0 h.o swap
2.5L HP mods can be found at www.4bangerjp.com/forums .
11-24-2006, 07:41 PM
Re: 4.0 h.o swap
Your gonna have to change everything pretty much and don't forget to get stiffer springs for your new weight gain
11-24-2006, 10:09 PM
Real Name: Harry
Re: 4.0 h.o swap
If you are going to go through all that trouble, you might as well put a Vortec 4.3 V6 or a small block Chevy V8 in there.
11-25-2006, 04:52 PM
Re: 4.0 h.o swap
Keep the XJ and the TJ.....thats a great solution.
| Thread Tools |
| Display Modes |
Linear Mode
