Go Back   Jeepz.com > Technical Forums > Jeep Performance
This section Sponsored By
Old 06-08-2008, 03:09 PM
PA-XJ2's Avatar
Real Name: Ant
4.0 header
hey, i have a 97 TJ(4.0L auto) and im going to install a header but im not sure witch on to go with, Edelbrock shortys, or pacesetter full length header?
-AnT
97 TJ, MSD, K&N filter. Keep Jeepin
View Public Profile Send a private message to %1$s Show PA-XJ2 gallery
Old 06-08-2008, 04:30 PM
Poobah's Avatar
Real Name: Poobah
Re: 4.0 header
I also have a 97 TJ 4.0L and just replaced my header last week. I researched quite a bit and narrowed it down to two companies: Borla or JBA...and I ended up going with the JBA shorty (cat4ward). I don't know much about the two you listed. One of the big reasons I chose JBA is because they are headquartered locally (San Diego) so if I have any problems I can go right to them...plus I like supporting the smaller local business. My research turned up a LOT of happy customers and good referrals. This is what they say on their website:
Jeep vehicles are know for being rugged machines that can go just about anywhere. With rugged designs and time proven engineering, these purpose built vehicles are right at home when venturing off the beaten path from Moab to the Rubicon. Most Jeeps are powered by the trusty 4.0L I-6. Unfotunately, the 4.0L has always suffered from an inefficient and crack prone exhaust. Many Jeep enthusiasts know the frustration of a cracked factory exhaust manifold or a trail damaged exhaust system - not to mention a need for more torque. Until now, there hasn't been a quality solution to these issues. JBA's engineering team spent over 2 years developing the most durable and best performing header and exhaust system possible. These systems are designed for the hardcore user to get you the power and torque needed to conquer anything in your path.
JBA Cat4wardŽ Headers :: Wrangler 4.0L
If you own a Jeep powered by the 4.0L I-6, you know that it is a solid dependable powerplant. Depending on what year vehicle you have, you may also know that it is short on power and torque and has a tendancy to crack exhaust manifolds. JBA has spent countless hours developing and testing the ultimate solution for these power and durability challenges. JBA's unique headers designes are crafted from the highest grade materials to ensure lasting performance for your Jeep. The head flange is a one-piece design that is CNC laser cut from 1/2" steel plate to guarantee a tight seal with the head. JBA's collector features a 3/8" flange secured with a 360 degree weld for maximum strength. Each kit includes high quality hardware and gaskets for a professional no-leak installation. Don't settle for low grade materials and inferior designs.
91-99 Jeep Wrangler 4.0L - p/n 1526S
If you own a Jeep powered by the 4.0L I-6, you know that it is a solid dependable powerplant. Depending on what year vehicle you have, you may also know that it is short on power and torque and has a tendancy to crack exhaust manifolds. JBA has spent countless hours developing and testing the ultimate solution for these power and durability challenges. JBA's unique headers designes are crafted from the highest grade materials to ensure lasting performance for your Jeep. The head flange is a one-piece design that is CNC laser cut from 1/2" steel plate to guarantee a tight seal with the head. JBA's collector features a 3/8" flange secured with a 360 degree weld for maximum strength. Each kit includes high quality hardware and gaskets for a professional no-leak installation. Don't settle for low grade materials and inferior designs."
I probably didn't help but thought I would throw my two cents in there since I was just in the same boat and went throught the same process you are going through now. So far I am happy with the decision to go with JBA, but it has only been a week so I can't give a solid review yet.
I found out that this engine is notorious for cracked exhaust manifolds...The wisdom is that if you haven't already replaced your header or aren't in the process of doing it now, then you are about to have to do it... Quite a bit out there on the subject if you are interested.
Check out their website if you are interested. JBA
Good luck!
97 TJ Sport-4.0L-Green: 33X12.5's (BFG AT)-Amrcn Rcng Chmbr Tfln whls; 4" Tera lift; JBA Header; 4.56 Grs; Body Armor rear bmpr w/Swing-Away tire carrier, 2 jerry cans, & hi-lift jack; Body Armor frnt Triple Hoop bmpr w/ Smittybilt XRC-8 Winch; Tuffy expand-a-trunk, cntr cnsl, & glv bx; Wet Okoles; Cobra 75WX; Viair onboard air-450C/2.5; K&N Air; Optima Yllw Top; 4 Hi-Liters; Bestop Fndrs; Yakima Rk; Ravelco ...and more coming!
View Public Profile Send a private message to %1$s Show Poobah gallery
Old 06-08-2008, 05:57 PM
PA-XJ2's Avatar
Real Name: Ant
Re: 4.0 header
hey thanks man, i looked at that header, cat forward, dose that mean that it replaces the down pipe?
  #4 (permalink)
Old 06-09-2008, 08:33 AM
Poobah's Avatar
Real Name: Poobah
Re: 4.0 header
I had a shop do the install for me so I am not 100% on the answer, but if you look at the installation instructions, they might shed some light. Here is a link for the model I think you need:
http://products.jbaheaders.com/asset...eets/1526S.pdf
...or a quick phone call to them might clear it up. I'd assume by the name cat4ward that everything from the cat forward is included...but you know what they say about assumptions! Good luck!
  #5 (permalink)
Old 06-11-2008, 08:33 PM
PA-XJ2's Avatar
Real Name: Ant
Re: 4.0 header
hey thanks man!
-Ant
  #6 (permalink)
Old 06-12-2008, 10:09 AM
jeepster357's Avatar
Member
Real Name: jeepster357
Re: 4.0 header
I have a buddy that runs a Banks header and catback exhaust, sounds nice and did add power. not sure on his actual specs though.
View Public Profile Send a private message to %1$s Show jeepster357 gallery
  #7 (permalink)
Old 03-19-2009, 04:23 PM
Real Name: mike
Re: 4.0 header
make your own
View Public Profile Send a private message to %1$s Show fishoutofwater gallery
  #8 (permalink)
Old 03-19-2009, 04:24 PM
Real Name: mike
Re: 4.0 header
cant be too hard
  #9 (permalink)
Old 03-20-2009, 05:04 PM
Collin the Hen's Avatar
Jeep :
Year :
Lift :
Tires :
CJ-7
1984
3 inch
31's
Real Name: Collin
Re: 4.0 header
What the heck?
View Public Profile Send a private message to %1$s Show Collin the Hen gallery
  #10 (permalink)
Old 03-20-2009, 05:05 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: 4.0 header
Looks like a spammer.
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
  #11 (permalink)
Old 03-20-2009, 05:08 PM
Jeep :
Year :
Lift :
Tires :
CJ-7
1984
3 inch
31's
Real Name: Collin
Re: 4.0 header
I'll kick your cyber butt!!!
  #12 (permalink)
Old 10-21-2009, 12:13 AM
Real Name: Mike
Re: 4.0 header
how much over stock can you expext with a new header and muffler? HP and tourqe wise?
View Public Profile Send a private message to %1$s Show palehawaiian gallery
  #13 (permalink)
Old 12-06-2009, 03:38 PM
Sid1966's Avatar
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
1997
2.5" susp. lift 2" body
35x13.50x15 Krawler
Real Name: Sid Prouty
Re: 4.0 header
i am very happy with the Banks header 3 yrs no leaks dont know about hp gains but throttle responce is much better
View Public Profile Send a private message to %1$s Show Sid1966 gallery
HEI, Header YJ w 258 Magua308 Items for Sale, Trade, or Give Away 0 07-08-2006 01:41 AM
header OhioMike CJ YJ TJ and JK 1 05-06-2005 07:44 AM
Header question BigDaddys88YJ CJ YJ TJ and JK 0 02-27-2005 01:16 PM
4.0 header compatibility jeep90 Cherokee, Commander, Wagoneer and Liberty 3 10-08-2004 07:14 PM
which exhaust header to buy? spabrai CJ YJ TJ and JK 5 07-20-2003 07:00 PM
 Subscribe to our RSS feed
