06-12-2008, 01:00 AM
Real Name: Angie
need for speed
I'm looking to squeeze a bit more speed off the line from my 4.0L YJ automatic. It runs great, it just doesn't have quite the get up and go that I'd like. I was thinking a set of headers or maybe new exhaust, any suggestions?
06-12-2008, 06:08 AM
Administrator
Real Name: Terry Mason
Re: need for speed
What year YJ? Does it have a carb?
06-12-2008, 10:06 AM
Member
Real Name: jeepster357
Re: need for speed
Not sure what your fuel supply set up is but I sure preach the gospel of after market cold air intakes and throttle body spacers. Its not gonna win you a drag race but on my manual trans it has reduced the amount of downshifting on steep grades and given me a little more zip while passing on the highway.
06-12-2008, 10:51 AM
Moderator
Re: need for speed
Do you have stock size tires? If larger than stock, regearing the axles to lower gears will be the number one improvement to off-line driveability.
If you're YJ is a '91+, I'd recommend a 62mm throttle body (like the ones I sell). They greatly increase airflow to the engine and it removes the taper beneath the throttle plate that restricts airflow for the first 1/4" of throttle movement. Throttle response is increased dramatically.
06-12-2008, 03:34 PM
Member
Re: need for speed
I agree with bounty hunter. gears best bang for the buck
Make mine an old CJ with a V8 and no top!
06-12-2008, 11:12 PM
Real Name: Angie
Re: need for speed
It's a 93, fuel injected, w/31 inch mudders. I hadn't thought of the TBS, I'll go that route first. Thanks
06-13-2008, 12:49 AM
Moderator
Re: need for speed
The 62mm TB will do more for you than a spacer, but the 62mm TB and a 62mm spacer would be even better. I know somebody that sells both, pretty cheap
Also consider injectors from a mid '90s Ford v8, either Mustang or Crown Vic.
Then there's the Livewire kit from Performance Distributors for a hotter ignition system, plugs gapped at .065".
06-14-2008, 12:53 PM
Real Name: Paul
Re: need for speed
bounty hunter
Does a 97 4.0 have a 62mm throttle body? Just curious if i could beneifit from that.
thanks
06-15-2008, 11:49 PM
Moderator
Re: need for speed
I believe the stock 4.0L TB is only 55mm, with a restrictive taper beneath the throttle plate.
Here's a pic comparing my 62mm TB to a stock 55mm TB.
06-16-2008, 12:55 PM
Real Name: Angie
Re: need for speed
Bounty__Hunter
Do you have a website I can peruse where you sell this stuff?
06-16-2008, 08:53 PM
Moderator
Re: need for speed
No website, just me, either sites like this one or on Ebay.
Nothin really to peruse but 62mm TB's and the occasional 62mm spacer.
06-17-2008, 01:55 AM
Member
Re: need for speed
A turbo can fix anything
06-21-2008, 08:43 AM
Real Name: Jay z Jeep Junkie
Re: need for speed
Bounty Hunter,
what would be your suggestion for the 4 banger.. I have 92,wrangler fuel injected
besides dropping in a v8 !!!
06-22-2008, 07:07 AM
Moderator
Re: need for speed
My suggestion would be to regear the axles to match any increase in tire height, and add performance mods as your budget allows. My 2.5L is fun to drive, very responsive and holds its own.
08-14-2008, 04:47 PM
Official Vendor
Real Name: tom
Re: need for speed
i can sell you a 68mm throttle body. i am a distributor for one of my sponsors. F&B Throttle Bodies
08-14-2008, 04:52 PM
Official Vendor
Real Name: tom
Re: need for speed
cheaper than buying direct
08-14-2008, 08:26 PM
Real Name: Angie
Re: need for speed
I had to do an unexpected rebuild on the motor about a month ago and went ahead while I had the whole thing pulled out and put on a set of banks headers and the 62mm TB and spacer and I got exactly what I was looking for. Throttle response improved dramatically with that combo, I couldn't be happier. Now if I could just afford the cool air intake and exhaust...might have to shoot off a letter to Santa.
| Thread Tools |
| Display Modes |
Linear Mode
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Vibes at speed
jay79cj7 |
Cherokee, Commander, Wagoneer and Liberty |
2 |
06-30-2005 11:41 PM |
Cj5 Speed
jeeprostyle |
CJ YJ TJ and JK |
18 |
07-15-2004 12:45 PM |
Speed-o-meter
Natty |
CJ YJ TJ and JK |
7 |
07-20-2003 07:00 PM |
97 tj with a shot 5 speed
rockwrangler |
CJ YJ TJ and JK |
4 |
top speed?
LGR |
General Chat |
22 |
