    Oct 2005
    mile marker 52...in the Florida Keys
    91
    o2 sensor simulators?
    do they exist for the jeep?
    planning to enlarge the rear exit off the cat to 2.5"...into a 2.5" muffler and tail pipe.
    but if i don't have to install an o2 bung for the rear sensor, and just use a simulator to keep the PCM happy...i will.
    any help??
    i know they make em for chevies and fords when removing the cats....do they make em for the Jeeps?
    2003 4.0L wrangler
    ARREST-ME RED 99 Z-28, M6
    TSP Torquer cam (233/233 .589\" 112*), Spec 4 clutch, Alum FW, LS6 intake, harland sharp rockers, Flowtech LTs, 3" true duals exhaust, SSRA, TSP lid, ASP pulley, BMR suspension, 315 drag radials out back
    400rwhp...looking for more
    audioatg's Avatar
    audioatg is offline Junior Member
    Nov 2008
    13
    Re: o2 sensor simulators?
    Hummm not sure If they make them anymore. Think they are not allowed to sell them. But Not sure what place I got mine from its either from jeggs or summit. I got one for my dodge dakota. Got a 3.9 cat kept going bad hollowed it out.
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,256
    Your problem is that the '03 has more than one o2 sensor, and are they the same?
    TJ_Jeep's Avatar
    TJ_Jeep is offline Senior Member
    Nov 2008
    A little place in the wettest dry county in Alabama
    494
    Quote Originally Posted by fast_Z28_guy View Post
    any help??
    2003 4.0L wrangler
    what i did when i but my glass pack on is i took the convertor off and welded a a peaice a pipe to the exaust pipe with a nut in the middle and screwed the sensor middle in the it works perfect and no check engine light heres a pic of it you can see the sensor in the back
    Oct 2005
    91
    what year jeep is it? is that just the front o2 sensor?
    what i need is the rear sensor. which registers the efficiency of the cat. i would think if you remove the cat but put the sensor in it would still have "check engine" codes for a faulty cat.
    TJ_Jeep's Avatar
    Nov 2008
    494
    its a 98 and that is the rear sensor that went behind the cat by leaveing the sensor out it still picks up the heat but it picks up the fresh air telling the computer that if it were in the converter it would say that the converter is doing a good job. its just a way to "trick" the sensor
  7. #7
    Nov 2002
    Southern Illinois
    13,256
    It's hard to tell from his pic, but it looks like he welded a small section of tubing, open at the ends, to the exhaust tubing. The o2 then warms up properly but on sniffs clean air as it doesn't enter the exhaust tubing.
  8. #8
    TJ_Jeep's Avatar
    Nov 2008
    494
    Quote Originally Posted by Bounty__Hunter View Post
    you hit the nail right on the head
  9. #9
    Oct 2005
    91
    so it's basically just laying next to the pipe?
    interesting.....can't beleive that works.
  10. #10
    TJ_Jeep's Avatar
    Nov 2008
    494
    yup thats it.
  11. #11
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    I wonder what happens when Water or Mud gets to the sensor if it's open like that. Does anyone know?
  12. #12
    TJ_Jeep's Avatar
    Nov 2008
    494
    Quote Originally Posted by SteelHeadz View Post
    i've had water and mud hit mine seemed fine to me
  13. #13
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    That is Interesting.
  14. #14
    riden dirty's Avatar
    riden dirty is offline Junior Member
    Mar 2009
    SW Louisiana
    25
    whats behind the glasspack in the pic? Is there a stock tailpipe or is it just open? How's the sound?
    You don't have a jeep unless you have a Jay in it!!!
  15. #15
    TJ_Jeep's Avatar
    Nov 2008
    494
    Quote Originally Posted by riden dirty View Post
    Its the stock tail pipe. At idle it has rumble sound which sounds pretty good, I plan on running duals here soon
    My Jeep has a 5th gear??
  1. O2 Sensor
    By Jeeper99 in forum General Chat
    Last Post: 09-21-2008, 10:30 PM
  2. IAT Sensor - Where is it?
    By groverboy in forum CJ YJ TJ and JK
    Last Post: 07-25-2006, 10:42 AM
  3. TJ 2.4L O2 sensor
    By mud4feet in forum CJ YJ TJ and JK
    Last Post: 01-19-2006, 09:22 PM
  4. o2 sensor went out
    By phattie in forum CJ YJ TJ and JK
    Last Post: 04-08-2005, 11:16 PM
  5. O2 sensor??
    By superfiveo in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-14-2003, 04:59 PM
