4.0L Engines
Hey does anyone know if I can get a 4.0L motor and ax15 tranny out of a 97-Present Jeep Cherokee and put it in my 95 YJ?  Trying to use a newer engine in my YJ, since I went 4wheelin this past weekend and didnt have the torque that i wanted. If this is possible, what all do i need to get out of the donor car, so I can make this work? Do I need to modify my TC to fit the new tranny, or can I just take the TC from the donor and use the driveshaft I currently have in there? Just trying to make sure when I start pulling things, I get everything.
Thanks in advance,
95 YJ 2.5L, AX5 tranny, N231 Transfer case, Aluminum Radiator, 2.5" BDS suspension, 3" Poly Body Lift, AirRaid Cold air intake, .62mm TBS, Bored out Intake Manifold with 4.0L TB, 31"X10.5" BFG Land Terrain
