Welcome to Jeepz.com.
Results 1 to 8 of 8
    Clueless Jeeo Beginner's Avatar
    Clueless Jeeo Beginner is offline Junior Member
    has no status.
    Aug 2012
    2
    Shocks with new lift kit
    I bought brand new Rancho Rs5000's for my yj a couple months ago and I was also wanting to get the rubicon express 4in lift but without the shocks, could my RS5000's work fine with the rubicon express lift?
    steady.foot's Avatar
    steady.foot is offline Senior Member
    steady.foot is
    a dirt digger
    Oct 2011
    central maine
    353
    Type of Jeep
    YJ Wrangler
    Re: Shocks with new lift kit
    If the shocks were bought for a jeep with no lift, they will be to short for a 4" lift. They will fit on there but will be close to there extended travel.
    If you want to drive a sports car, Buy a mustang.
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    5000's are some pretty stiff gas-charged shocks. May want to consider selling them and getting some hydraulic shocks if you're looking for a smoother ride.
    has no status.
    Aug 2012
    2
    Quote Originally Posted by steady.foot
    Sorry I wasnt being very specific, I bought them with a 3in body lift, I'm just going to take the body lift out and add the 4in express lift to it. The extended length of the front is 25.250 and the back 20.250
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    998
    Type of Jeep
    CJ-5
    A body lift does not increse the distance between the top shock mount and the lower, You could put on a 12" body lift and run the same shock because nothing has changed in the suspension. 25 and 20" dont seem to bad though. Only thing to really do is install you lift and before putting the shocks on, stretch them out and see how much travel you will have. If you dont have what you want, then just run your current shocks until you can get the correct ones.. Running a shorter shock will only limit your susupension travel off road, so using them now will be fine but you will not win any suspension flexing contest, lol.
    flipper349's Avatar
    flipper349 is offline Junior Member
    flipper349 is
    has no status.
    Jan 2011
    Litchfield,Mi.
    9
    Type of Jeep
    YJ Wrangler
    so if I took the shocks off and let the axle drop, my shocks should at lease be that long for the most flex
  7. #7
    69jeepcj's Avatar
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    998
    Type of Jeep
    CJ-5
    I must have been in a hurry when I responded and used poor words. With the shocks off, Try to get your suspension to do something like this. Passenger side front is extended, and driver side is compressed. Measure each side from top shock mount to lower shock mount. you will need a shock that measures "x" amount fully compressed, and "x" amount fully extended. This will give you the most out of your shocks and allow full use of your suspension travel.
  8. #8
    flipper349's Avatar
    flipper349 is
    has no status.
    Jan 2011
    Litchfield,Mi.
    9
    Type of Jeep
    YJ Wrangler
    thanks I didn't think about the compressed part of it
    phil
  1. Lift and shocks
    By Timlt1 in forum CJ YJ TJ and JK
    Last Post: 08-03-2012, 07:35 PM
  2. Lift or just new shocks
    By Sblanck in forum CJ YJ TJ and JK
    Last Post: 08-08-2009, 08:50 PM
  3. Stock shocks with a lift?
    By AdamControl in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-23-2005, 06:51 PM
  4. shocks for a 2" shackle lift?
    By Greencuke in forum CJ YJ TJ and JK
  5. new shocks with lift?
    By rtoney9 in forum CJ YJ TJ and JK
