Tony Marc
So the time has come to replace the thin rear crossmember my 85 CJ originally came with. I already have a heavy duty one ready to go. An old timer where I work told me a should weld a temporary brace behind the original before cutting it off. His thought was, if you cut off the rear crossmember off, the frame rails may have a tendency to spread apart from each other. The temporary brace would hold the two frame rails in place while the new crossmember is put back.
Anyone ever do this? Or found the frame spreads apart when the crossmember was cut off? I would think if there was that much tension, the frame would show some signs of that by now.
I can easily do the temporary brace and cut it off and grind it flat later.... But is it necessary ? Or just plain overkill ?
Thanks.
Thanks.
