throttle body
Kevin Ayres
looking for the thread for the swap on the throttle body 2.5 and if you got to bore out the intake manifold,and what spacer to use. thanks
check out the link i gave you. that guy was a 2.5 guy and went through all the different mods and then to a 4.0 and finally a v8. he does machining on throttle bodies too,  if you need one bigger then a 4.0.
i have used his over bored 4.0 ones on my 4.0s, previously, and they are worth the money
