Teraflex 2.5 Jk lift kit
CoorsLight29
I am getting a teraflex 2.5" lift kit for a jk complete with everything with a set of wheels and tires I'm purchasing.. I own a tj so the lift does me no good... My question is will this lift only work on a jk or will it also work on a yj? Any info helps....
It will not fit on your TJ! Sell it and buy the correct lift. Plus the wheels will not fit. JK are 5x5.
The wheels will work with using a spacer that will take my tj from 5 on 4.5 to 5 on 5 bolt pattern and I wasn't wanting the lift for my tj I'm already sitting on 6 inches of lift...
It's A Jeep Thing!!!
why are you getting the lift then? the way you asked the original questions sounded like you were getting it for the tj.
sometimes, if its a spacer block lift, you can use those blocks on other vehicles. and sometimes the springs fit other vehicles also but its rare
