CJ Doors
Mtpockets
Can someone tell me if TJ or YJ full doors will fit my 1980 CJ7? Will I have to make modifications for either to work?
forget the tj doors. the yj doors will fit. Don't think any mods are needed as the tub dimensions are the same. Maybe diff hinge locations
they do bolt on with only minor adjustments for alignment. and maybe a little tilt fore or aft on the wind shield. only other consideration is how the latch style is. cjs have wo different striker styles, a round bolt style striker and a flat striker. that will affect your door latching. i was able to use flat doors on my yj, with a home made flat striker using a bolt, some washers for spacing, and a piece of flat steel cut and bent to the shape i wanted. i am not sure if you can make a round striker rod fit on a flat striker tub though as i never had a flat striker tub. probably can be done with some creativity though.
I've got your doirs, just the metal you can buy all new parts at4wheel hardware they are from an 81 cj 7 , .
repaired and primed , posted on craigslist knoxville Tn
200.00 its a steal. they just got to go
