01 cherokwe limited just died
My 01 cherokee limited just died. Start back up rough and made it home. Now won't start. Turns over just won't start. I can hear the fuel pump turn on but don't know how to check if it's working. 150k on this strait 6
150 K on a 4.0 L is just the break in milage. Some common things to check and replace is your fuel filter. Once you get it running again change your oil and oil filter and air cleaner and it will give you at least a 100 K more miles.
i would check your sensor on the transmission bell housing. i cannot remember what its called but i think cam or crank position sensor. anyways, if you look down between the firewall and back of the engine, sometimes you can see it right on the driver's side top of the bell housing. it will give you the trouble you are having
