dandoc
So my YJ (Project Salt) is finally back in my possession after a few months of it being garaged (in another state, nonetheless). What I'm noticing now is the engine temperature gauge tops out around 150 degrees F. If I remember correctly, it used to be closer to 200 F. Last year the whole coolant system was drained in order for me to remove the body from the frame; the system was then filled with new coolant and a new drain plug installed. Does this lower temperature gauge reading mean that my thermostat is in need of replacement? If the current thermostat stays in, what ramifications, if any, might I expect? Thanks in advance.
