Hi folks. I hope someone can help. I have a 2002 GC Laredo, 4.0 engine, 42RE transmission. Here is the problem: error code shows only P0135 for the O2 sensor. It shifts into reverse fine, shifts into drive fine, but while driving it won't shift out of first. I have had it up to over 3000 rpm. There is a whine coming from the transmission which changes pitch when shifted from park into reverse, and from reverse into drive. After changing the radiator, water pump and thermostat, still the same problems. Any suggestions or ideas are greatly appreciated.
