2000 - 2004 Jeep Grand Cherokee Ignition Coil Pack for Models with L6 4.0L
1ATony
The ignition coil pack is a crucial part of your ignition system. It's function is to convert the 12 volt power of your vehicle's electrical system in to 35,000 or more volts. This produces a high intensity spark at the spark plug which then ignites the fuel in the cylinder. Coils in general will wear out over time and cause a misfire condition. In engines like this that use a coil pack, if one coil goes bad, the complete assembly needs to be replaced.
This Ignition Coil pack features the following specifications:
New not remanufactured
Replaces dealer part numbers: 56041476AB, 56041476AA
Built to strict quality control standards
Direct replacement
100% factory tested
Fits the following Jeep 6 cylinder engines as listed:
L6 4.0L
Backed by 90 Day warranty
These are electrical parts and are all tested before they leave our manufacturer. This electrical item is not returnable; it is only eligible for exchange.
This part replaces:
HOLLANDER #: 610-02833
OE #: 56041476AA
