PLEASE VISIT OUR WEBSITE FOR CURRENT PRICES
2003 - 2006 Jeep Wrangler Timing Belt Kit with Water Pump (with Tensioner Arm)
Gates (TCKWP265A) Water Pump and Timing Belt Component Kit
This Gates timing belt component kit, tensioner with water pump is just what you need to keep your vehicle in good running order.
Our timing belt sets come from a company that is commited to supplying components that are engineered and manufactured under strict quality control procedures. They are leaders in timing component quality which provides you with the highest quality parts available on the market.
This high quality, water pump and timing belt kit, contains the following pieces and has the following specifications:
(1) - Timing Belt
(1) - Tensioner
(1) - Tensioner Arm
(1) - Idler
(1) - Water pump
(1) - Water pump gasket
Most car manufacturers recommend changing your timing belt between 50,000 and 70,000 miles (consult your owner's manual to see what your specific manufacturer suggests).
FREE SHIPPING IN THE LOWER 48 STATES. NO HIDDEN PACKAGING FEES
