1997 Jeep Grand Cherokee Driveshaft Front for V8 Engine
1ATony
Check here for current pricing:
This FRONT Jeep Driveshaft is a newly remanufactured part that has been rebuilt to very strict quality control standards. It is just what you need to get your vehicle in good working order!
Specifications:
Replaces FRONT Driveshaft
Rebuilt to strict quality control standards
No core charge
Construction type:
Transfer Case Side: Double Cardgan /U-Joint Type
Front Axle Side: CV-Joint with 6 Bolt Circular Flange
3 Year Manufacturers Limited Warranty*
Next Day Air Shipping available at extra cost
Correct for models with V8 Engine
Does not fit models with 4.0L
Features & Benefits of this rebuilt driveshaft:
100% Dynamically Balanced. - Reduces vibration and increases joint life. Dynamic balance is better than static because the unit is balanced at the speeds it will see on the vehicle.
100% New Universal Joints Installed. - Ensures proper fit & function for optimal performance and durability
All slip yokes are lubricated to O.E. specifications to prevent premature wear.
High speed balancing at 3200 RPMs ensure vibration-free operation.
All shafts are measured to guarantee proper fit.
Drive shafts may need replacing for a variety of different reasons. On vehicles that do heavy work or endure other extreme use you can actually break a driveshaft or twist it. Many plow trucks will actually break the CV or Universal joints trying to push heavy wet snow. More often the CV or U-joints wear out causing noises and vibration while accelerating or slowing.
*Backed by manufacturer's Limited 3 Year warranty. In the event this driveshaft should fail due to manufacturing defects during intended use, we will REPLACE the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty
