1999 - 2001 Jeep Cherokee Front Wheel Bearing & Hub Assembly for Models
1ATony
CHECK HERE FOR GREAT PRICING 1999 - 2001 Jeep Cherokee Front Wheel Bearing & Hub Assembly for Models with Full Cast Rotors Pair
FREE SHIPPING ON ALL ORDERS
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
3 Bolt Flanges
Fit 5 Lug Wheels
Replaces dealer part numbers: 5016458, 5016458AA, 53007449AC
New wheel studs installed
Direct replacements
Built to strict quality control standards
For models that came equipped with Cast Rotors only
Overall rotor height of 3-1/16" and 2-1/8" rotor hat height
Note: If you have any questions about this fitting your application, please call your local Chrysler Jeep dealer with the above part number.
Quality
1A Auto exclusive 2 Year Warranty.
If this wheel hub & bearing should fail to provide satisfactory performance you may exchange it.
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto wheel hub & bearings are all tested prior to shipping.
Fit Guaranteed
This hub & bearing will install just as your original does. You can use your existing hardware.
Save time and money with this direct fit hub bearing assembly. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
1. Jack the vehicle up and support with proper jack stands.
2. Have a helper hold the brake pedal while you loosen the Axle Shaft Nut. This usually requires a large socket (30mm or larger) and impact wrench.
3. Remove the brake caliper and brake rotor. Use string or a plastic tie to hang the caliper up and out of the way.
4. Unplug ABS sensor (if applicable)
5. Unbolt the hub flange. The hub may come free from the axle shaft easily, if not, use a gear puller or similar tool that pulls on the hub while pushing on the axle shaft. DO NOT try to drive the axle out with a hammer, this could ruin your axle CV joints.
Reverse order to install.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
Installation
2. Remove the wheel and tire.
3. Have a helper hold the brake pedal while you loosen the Axle Shaft Nut. This usually requires a large socket (30mm or larger) and impact wrench.
4. Remove the brake caliper and brake rotor. Use string or a plastic tie to hang the caliper up and out of the way. DO NOT allow the caliper to hang by its own brake hose.
5. Unplug ABS sensor (if applicable)
6. Unbolt the hub flange. The hub may come free from the axle shaft easily, if not, use a gear puller or similar tool that pulls on the hub while pushing on the axle shaft. DO NOT try to drive the axle out with a hammer, this could ruin your axle CV joints.
7. Reverse order to install.
We were able to do a removal and replace on a GM car in about 45 minutes.
NOTE: If you are unsure which of your hubs is bad listen while you turn the wheel slightly. If you hear the noise while you curve to the right and it goes away when curving to the left your RIGHT hand or passenger side hub is going bad and vice versa. In our experience replacing both hubs is best even if only one is bad. Most likely the other side is gong to go bad soon. Original Equipment (OE) hubs usually last to just over 100,000 miles.
This part replaces:
Reference #: 513158 x2
