ARB Special from 3 Jeeps Offroad!
3JeepsOffroad
Now is the time to lock your axles!
Buy any front or rear ARB air locker and receive the CKSA12 compressor for free! Save $180 with that deal. Permanently mounted, this compressor is installed into your truck and includes a full wiring loom with air locker solenoid plug in contacts, mounting hardware with reinforcing bracket and quality compressor isolating switch. This compressor is designed to activate up to two ARB air lockers.
Or buy two ARB air lockers and receive the CKMA12 compressor for free! That's a $280 compressor for free!
The CKMA12 is powerful enough to air up your tires, it just needs the 'Inflation Accessory Kit'! So what makes this compressor special? It's small enough to fit into even the tightest space and quiet enough to mount in the cab. It has enough output to air up four 35" - 37" tires in a single duty cycle and typically airs up a 35" tire in just over two minutes.
And we'll throw in the Inflation Accessory kit FREE as well, with a two locker purchase!
