1999-2001 Jeep Cherokee Front Wheel Hub & Bearing Pair with CERAMIC Brake Pads & Roto
1ATony
VISIT US HERE FOR GREAT PRICES 1999-2001 Jeep Cherokee Front Wheel Hub & Bearing Pair with CERAMIC Brake Pads & Rotors Set for Models with Full Cast Rotors
FREE SHIPPING IN THE LOWER 48 STATES!!!
This wheel hub bearing assembly, brake rotor, & brake pad set is just what you need to get your vehicle in good stopping order again!
Brake Pad Specifications:
4 Piece FRONT Brake Pad Set
No core charge
Includes shims
Professional Grade CERAMIC ENHANCED METALLIC Disc Brake Pads
Brake Rotor Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
Replaces dealer part number: 5016434AA
Fit 5 Stud Wheels
Direct replacements
Wheel Bearing & Hub Assembly Specifications:
Comes as a PAIR
Fits both the RH (Passenger Side) & LH (Driver Side) FRONT
3 Bolt Flanges
Fit 5 Lug Wheels
Replaces dealer part numbers: 5016458, 5016458AA, 53007449AC
Studs already installed
Direct replacements
Fits models that came equipped with Cast Rotors only
Overall Brake Rotor Height of 3-1/16" and 2-1/8" Rotor Hat Height
This wheel hub bearing assembly, brake rotor, & brake pad set makes great replacements and has good value over the price of dealer parts.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
