JK Big Brake Kit (Front) Weekend Special Free Shipping in the 48 US.
Allen's Offroad
Click on image above and add to cart for best pricing. You will be happy you did.
Allen
Fits:
Jeep Wrangler (JK) (2007-2017); Front; Completely Bolt On With No Cutting, Welding or Spacers Required.
RT Off-Road's Big Brake Kit is the solution to the strain that oversized wheels and tires place on the braking system on any JK Wrangler. This Brake Kit features Calipers with a pair of 54mm pistons for increased clamping forces, resulting in increased piston area over the single piston calipers. The 13″ vented Brake Rotors give the braking system greater leverage. The end result of the Big Brake Kit when compared to OE brakes is a 22% shorter 60-0 distance! 17″ wheels are required for installation.
Kit Includes Dual Piston Calipers w/ 54mm Pistons, Caliper Brackets, 13″ Diameter Rotors, Pads And All The Required Hardware For Installation. Larger bore brake Master Cylinder (Replacement Part #: 68091278AB) is also suggested for better brake pedal feel and greater braking performance.
:D
