    grg98zj's Avatar
    grg98zj is offline Junior Member
    Apr 2019
    4
    98 zj controle arm adjustments
    ok just got a 3 1/2 inch lift .all 8 controls arms need adjusting.is there a formula for this or correct uppers and lower adjustment measures or a process. I need help so any one please help.even if i need to go get a correct book.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,678
    Re: 98 zj controle arm adjustments
    Here is a video from Quadratec
    Regards,
    JPNinPA
    Sent using TapTalk
    grg98zj's Avatar
    Apr 2019
    4
    perfect.Just perfect.this is exactly what I needed to get it done.this video explained it all and showed it.this was GREAT help.JPninPA thanks a million.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,678
    Just understand the driveshaft angles you need for the joints and shaft you have.
    There are some other tips for setting. When I find them ill post up.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,678
    Post picks pf your build while doing it fir another good thread
    grg98zj's Avatar
    Apr 2019
    4
    thanks any more tips would be greatly appreciated. hey another thing I'm worried about is how long the uppers and lowers should be on a 3 1/2 lift.front and back.im reading fir that height stock length is a good starting point until I get to the alignment shop.
  7. #7
    grg98zj's Avatar
    Apr 2019
    4
    yea that was another thing I was needing and the video didn't explain length.
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,678
    Just reading this. Trigonometry. The length of one side stays constant. Control arm mount to point above axel on frame. The hight from axel to frame increased by 3.5 in
    Old
    x2 + y^2 = ca^2
    New
    x^2 + (y+3.5)^2 = (ca+n)^2
    CA = old control arm length.
    N is how much longer than stock.
    This should be close
  1. Speedometer Adjustments
    By KidLoco747 in forum CJ YJ TJ and JK
    Last Post: 05-25-2012, 03:17 PM
  2. Minor Adjustments
    By dobrz1ew in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-08-2008, 05:44 PM
  3. steering wheel adjustments
    By raptor_pilot in forum CJ YJ TJ and JK
    Last Post: 06-18-2005, 02:06 AM
  4. about timing adjustments?
    By chinard in forum CJ YJ TJ and JK
  5. Weber carb flooding - Need tips on adjustments
    By MudderChuck in forum CJ YJ TJ and JK
