Page 2 of 2 First 12
  1. #21
    Re: I stumped all the mechanics near me HELP
    Not sure what he tested but I have a donor motor that I’m gonna steal stock alt for
  2. #22
    Is there any kind of fuses or relays that might be bad...my buddy says it’s pretty much over bc the wiring harness would be the next replacement
  3. #23
    Feb 2009
    Dayton Ohio Area
    6,024
    Just to reiterate. Your issue and symptoms have not changed. Idles great but above 750 rpm and throwing a P0622 generator field F terminal control circuit. Then you put it into gear and rough idle and dies. Codes P1391 intermittent loss of CMP or CKP. Despite having changed both. And odd atypical jeep codes of P0361, P0362 and P0363?
    You are using a 1 wire alt that is not loading down even when in gear and is charging at 14.4v
    Did you use stock/OEM CKP and CPS?
    Have you checked the fuel pressure?
    If I ignore all the codes there is an issue that jeeps die in reverse or in gear when cold. The torque converter solenoid or the torque converter itself.
    Regards,
    JPNinPA
    Sent using TapTalk
  4. #24
    over break im gonna use this donor motor i have a swap back to the original alternator and original hookups. my buddy says that the whole thing is scrap at this point we replaced everything that we thought would fix it and still stumped.
  5. #25
    Feb 2009
    Dayton Ohio Area
    6,024
    Look into the torque converter solenoid or torque converter.
  6. #26
    I read in your post that the TB was replaced. After it was replaced is that when the idol was about 900rpm, if all of the gasket was not removed that could be a source of a vacuum leak. Also there have been known issues with the pin connectors on the IAC not making good contact in the plug. Unplug it and take a look at the pins.
  7. #27
    Apr 2003
    Pembroke Pines, FL
    330
    Looks like weve been hacked
    Sent from my iPad using Jeepz.com mobile app
  8. #28
    Feb 2009
    Dayton Ohio Area
    6,024
    Not hacked!
    Cracked!
    Keep on your garter!
  1. Mechanic is stumped
    By ctoffs in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-29-2019, 11:18 PM
  2. Mechanic is stumped
    Last Post: 11-26-2019, 09:21 AM
  3. Was stranded, now stumped
    By Bond--007 in forum Wrangler and CJ
    Last Post: 04-29-2015, 06:27 PM
  4. Stumped
    By Mcneer in forum Wrangler and CJ
    Last Post: 01-04-2015, 07:38 PM
  5. Stumped
    By floridajeeper11 in forum Wrangler and CJ
    Last Post: 07-05-2011, 04:05 PM
