1. Windshield screws 93 yj
    Have 93 yj. Need to remove #40 star screws out of windshield hinge, the two in front. They just spin and donít come out. Need advice on how to remove and replace. Please donít tell me I have to remove dash. Thanks.
    Re: Windshield screws 93 yj
    I don't know the particulars about your jeep but sometimes if you pry upward to put tension on it the screw will then be able to be removed - be careful with the paint.
    Quote Originally Posted by mark sr View Post
    ill give that a try. Thanks.
    Apr 2003
    Pembroke Pines, FL
    310
    You mean the interior windshield knob? You might have to get a wrench up behind the dash. But Iím just going off what my cj7 is like, and the parts diagram for a yj. Good luck!
    Sent from my iPad using Jeepz.com mobile app
    Feb 2009
    Dayton Ohio Area
    5,193
    The bolts are fastened to nutserts welded into the frame. If they broke loose you have to cut into the frame to put a wrench on them or weld them back in.
    But trying pry pressure mentioned above you will want to soak with penetrating oil and heat. They used blue loctite on mine and heating made it easier to break loose.
    If you striped the star bolt either drill out or weld in a cheap hex socket.
    Starting on one not stripped. Use a hardened socket driver with sharp edges. Many come rounded and they strip easily. Chip and Clean the paint out of the bolt where the star socket goes. Heat the socket red hot with a touch. Then impact remove.
    Regards,
    JPNinPA
    Sent using TapTalk
    Feb 2009
    Dayton Ohio Area
    5,193
    Here is a decent video just showing all the steps...
    Regards,
    JPNinPA
    Sent using TapTalk
  7. #7
    Thanks. Itís the two screws on the bottom part of the hinge Iím having trouble with.
  8. #8
    Thanks
  9. #9
    Feb 2009
    Dayton Ohio Area
    5,193
    Quote Originally Posted by IanJeep View Post
    Inside on the dash or outside on the cowl?
    Pics help.
  1. Idle Mixture Screws?
    By KCOnABQ in forum Wrangler and CJ
    Last Post: 08-21-2009, 01:01 AM
  2. stripped out screws on hardtop
    By saintsokwitit in forum Wrangler and CJ
    Last Post: 04-13-2006, 06:57 PM
  3. damn Chrysler screws again!
    By Jeeper84 in forum Wrangler and CJ
    Last Post: 09-22-2003, 02:52 PM
  4. Jeep Door Screws Ect.
    By sudsmaster in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-11-2003, 07:24 AM
  5. 4.2 Idle Screws
    By MudderChuck in forum Wrangler and CJ
Tags for this Thread
