    Red face fuel gage problem
    i have a 79 cj7 that i am having a problem with the fuel gage, i replaced the sending unit and a none factory gauge and it still won't work need help.I dropped the tank again after i put the new sensor in and checked it out and it looked good and double checked the wiring on the gauge any one having or Had this problem.
    Dec 2010
    Foresthill, California.
    10
    Re: fuel gage problem
    Does your temp gauge work the fuel and temp gauge share a common connection if one is bad it messes with the other.
    Don't feel so bad, my 78 gauge cluster works when it wants.
    Feb 2009
    Dayton Ohio Area
    6,666
    Quote Originally Posted by Mwells72774 View Post
    I don't think he does feel bad. He stopped complaining in 2011.
    For your issue have you verified you have good connections and clean grounds? Most electrical issues are ground connection relayed.
    fuel gage problem
    Not yet. The "dash" torque screws are rusted to the point they're mostly gone. Winter project. It rounds and drives now, minus the junk transfer case that's way past bad. Sounds like trolls hammering through the floor
    Where is a reliable wiring diagram available?
  1. Fuel Problem
    By Branjmb in forum Wrangler and CJ
    Last Post: 12-23-2010, 05:13 PM
  2. yj fuel problem
    By allabs5150 in forum Wrangler and CJ
    Last Post: 11-24-2005, 01:00 AM
  3. Another fuel problem
    By MikeB in forum Wrangler and CJ
    Last Post: 11-23-2005, 10:15 AM
  4. Fuel Problem
    By brockchildress in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-25-2004, 03:59 PM
  5. fuel problem?
    By hi_c in forum Wrangler and CJ
