Trouble removing crank shaft bolt....harmonic balancer
Lhotak92XJ
Need to replace harmonic balancer......
Which direction to loosen the crank bolt?
I am turning clockwise (on some advice,) and the bolt had turned a about 1 3/4 turns.
It's not getting easier and I'm afraid to break the bolt off in the crank if I am tightening.
A little advice from someone who has done this..............Thanks
[addsig]
