XJ Stalling
Joopin
Super Moderator
RE: Rear Brakes not locking up
Hey there, My dads 93 xj is stalling every once in a while. It runs great but recently it has been stalling after driving anywhere from 30 min to 2 hours. It doesn't start back up unless you let it sit for about 20 min.
We replaced the fuel filter, distribuer, rotor, and ignition coil.
Re: RE: Re: RE: This may be a first
Sounds like a bad catalytic converter, the stalling will come sooner with each use. The material in the catalytic converter restricts exhaust as it gets hot, choking the engine. This explains why it will run after letting it cool.
You can get high-flow replacement Catco converters for around $60 from www.jcw.com .
check the camshaft poitioning sensor and the vacuum lines. i had the same problems on my xj and c.p.s. was the problem
