cam position sensor question....
xjjunkie
RE: Hemi?
does anyone know if and how i can check my camshaft position sensor inside the distributor?...If this sensor is bad will it cause my jeep to have no spark...
thank you
matt h.
RE:
Never heard a bad cam pos. sensor affecting spark. I'll check my FSM and see if there is a way to check that sensor.
RE: Re: RE: Got nailed with vehicle inspection...need fender
thank you very much...its much appreciated.............
Leave the connector connected, prick the Blue wire with the positive lead and the Grey wire with the negeitive lead, should read close to 5 volts. Often lower voltage, XJ´s are old.
Disconnect the coil and have osmebody turn the notor over a few times the volt meter should pulse.
I´ve never done this test mayself, just repeating the test procedure.
I´ve foregotten and ran my XJ for days without the Cam position sensor connected? I don´t really know hoe critical it is or if it actually does anything.
If I am correct, the CPS only affects timing, not the delivery of spark.
