95 grand cherokee limted 6 cyl firing order help
ROB_213
I Need Help With The Firing Order For My 95 Grand Cherokee Limted I Have Numbers And There Not Workin I Have Everything On Right I Have 1-5-3-6-2-4 Clock Wise I Replaced The The Cap Rotor Plugs Wires And Coil I Got Platium Autolite Plugs And Professonal Autolite Wires Since Jeeps Only Take Champion Or Autolite Platium Plugs Any Help Would Be Great Thanx For Lookin
Rob
I'm coming up with the same firing order looking here... The cylinders are 1-6 from the front of the engine; front=1, back=6...
Thanx for you Reply it works now it was a bad cap or rotor button i replaced both the first ones i got must of not of worked it had the orginal plugs and wires distrabtor cap rotor button and coil and have 126,000 on it :lol:
