Worth it?
B192734
Hey I was looking at the K&N fipk and was wondering...
Is it really worth it? Is there a noticeable difference, or is it all hype? Or do you need other parts along with it to make it worthwhile?
its worth it... although you can get virtually the same setup from rusty's and a few other companies for quite a bit cheaper. k&n is just the "original" and i guess its personal opinion on whether or not it is truly a superior product. it does make a difference though... just check out the dyno tests.
The conical K&N filter and airtube setup is a very worthwhile mod, but it can be done many ways for a lot cheaper than the FIPK. I used to run Rusty's, and now run a 4.0L TJ airtube with conical filter on my YJ. I recommend Rusty's airtube and filter for an XJ. You will notice a difference, more power and much quicker throttle response. You will get more intake noise but nothing bad.
