88 Jeep Cherokee Overheating
NW Jeep
I own an 88 Jeep Cherokee and it is overheating. We have replaced the Thermostat, Radiator and Water Pump and it is still overheating. This is a closed system. Any suggestions... Thanks
Do you hear pressure release when you open the overflow tank?
Also jack up the rear of the jeep and remove the temp sending unit at the rear of the head to get all the air out of the system.
A swap to an open cooling system from a newer XJ is a good upgrade.
After burping the system as described in the link (Thanks) and a new cap for the reserve tank, all is well. Thanks for the information.
Glad to hear that your problems have been solved! Happy Jeepin'
