Thread: Code 705
02-06-2009, 07:46 AM #1
Code 705
Well took the Jeep in had new exhaust put on, steering stabilizer was shot so had that replaced and the TP sesnor was replaced. Now the new codes are for transmission Range Sensor Circuit malfunction (705 code) the mechanic said there were two Sensors the car could have and the difference in price is 170 for the common and 600 for the uncommon. So how do I know which one it is? I just want it all fixed so I can move on to more fun parts.
02-06-2009, 08:54 AM #2
Re: Code 705
So it's either a $170.00 Transmission range Sensor or a $600.00 TCM?..I would Check the The TRS connectors for a short, bent pins or pulled out terminals and Check the wiring for any chafing, open circuit, short to ground or short to voltage before i start replacing those expensive parts..
02-06-2009, 11:46 AM Thread Starter #3
Re: Code 705
Will checking/cleaning/fiddling help with getting back my reverse tail lights? I swear there are days with this vehicle I want to throw in the stick.
02-06-2009, 12:19 PM #4
Re: Code 705
See there, you left out a Vital symptom.. The Inop. Reverse lamp could be the reason why there's a TRS DTC.. Repairing that Isue involves testing a few circuits on the connector to the TRS.. check the connectors first and wires, wiggle the connectors while someone watches the rev. lamps..Make sure that the engine is not running, ignition is in the on position and gear in reverse..
02-06-2009, 01:06 PM Thread Starter #5
Re: Code 705
Sorry just found out this morning the lights weren't working. And now the engine light is off. Oh well it will be warmer tomorrow so dh and I will be playing under the hood to figure it all out.
02-06-2009, 01:13 PM #6
02-18-2009, 12:34 AM #7
trouble code 12
By wirefire in forum Wrangler and CJReplies: 1Last Post: 07-09-2006, 03:41 AM -
Posting code
By mingez in forum Forum relatedReplies: 8Last Post: 12-29-2005, 08:26 PM -
Code 11
By Green97TJ in forum Wrangler and CJReplies: 4Last Post: 03-20-2005, 10:41 PM -
TRANSMISSION CODE
By LilRed4.0L in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 11-06-2004, 03:03 AM -
Code 43..what is it?
By blackjeep in forum Cherokee, Commander, Wagoneer and LibertyReplies: 9Last Post: 01-10-2004, 10:56 PM
