Vibration maybe propshaft??????
jim8280
Hi there i just joined the forum and allready in need of some help
I have a 94 xj cherokee and was giving it a bit of welly in the dry,not a good idea i know but as i launched off and gave it the big one in the dry all was fine but now i have noticed a severe wobble!!
At slow speeds in 1st or 2nd it seems my gear stick moves side to side and when i get to 60mph+ it shakes like made!!
Do you think i may have twisted the propshaft or somthing
any replys will be very greatfull
many thanks
Jim
I have no idea what you are even saying.
bet you chiped or sherd teeth on grears or even twisted the drive shaft stock shafts arent that strong than again xj wasnt designed to do 4wd hole shots either
Make sure tires are still in balance, as a weight could have fallen off.
But then again I'm not sure what a welly is. Did you jump it?
