1. radiator drain plug
    hello, everyone, i can't seem to find the drain plug for the radiator on my 95 cherokee country, 2wd, 4.0. i've never drained it before so i don't know,
    Re: radiator drain plug
    They're usually on the driver side lower corner by the electricfan.
    i just looked and i didn't see it, looks like a normal drain plug correct???, or is it above where my steering column thing go into??, and is the lower radiator hose supposed to have a spring in it?
    Yes, its a normal drain plug. On the bottom corner of the driver side radiator, look for a small piece of rubber hose thats tucked away. This is the drain tube and above it should be the petcock for the drain. Not all radiator hoses have a coil in it.
  5. Re: radiator drain plug
    Mine is on the passengers side down low. I never mess with it. I put a big pan under the drivers side and disconnect the lower radiator hose on the pump end (or the radiator end if you want to remove the air box). Then wash down the area, with a little clean water. Takes a pretty big catch pan to hold it all.
    DO IT IN THE MUD!
  6. Re: radiator drain plug
    I have a 92 Cherokee 4.0 - and mine's on the bottom of the radiator, passenger side. It's diffcult to unscrew. Be careful when your unscrewing it, or you'll break it - that will cost you a new radiator.
  7. #7
    Thanks everyone but it seems thzt the owner before me. put in a after market radiator. but im just going to take off the lower hose on the radiator.
  8. Re: radiator drain plug
    You need to pull of the grill to access. Its on the pasanger side bottom!
  9. #9
    thanks ill give it a try
  1. oil drain plug
    By djc321 in forum Wrangler and CJ
    Last Post: 05-02-2005, 09:48 AM
  2. Drain Plug for NP 231
    By jps4jeep in forum Items for Sale, Trade, or Give Away
    Last Post: 08-31-2004, 10:42 AM
  3. AMC20 drain plug question
    By 1981CJ5 in forum Wrangler and CJ
    Last Post: 12-26-2003, 09:56 PM
  4. Manual Transmission Drain & Fill plug Location
    By ad5at in forum Wrangler and CJ
  5. manual transmission drain/filler plug
    By Bounty__Hunter in forum Wrangler and CJ
