    Apr 2010
    panama city beach florida
    52
    Help>> breaks not working :(
    Ok.. I needed new front pads. Not a big deal,. Well got the new pads in and discovered my bleeder valves were stuck to point that i stripped both of them, so i just decided to get new calipers. Put everything back together, Bleed all 4 lines. No air, new fluid coming from each line, BUT NO PRESSURE ON PEDAL when running?? When the jeep is not running it acts normal, pump pump tight. When running nothing! any ideas?? did i get a bad caliper??
    94 Cherokee Laredo awd 4x4 5.2 auto
    High flow cat, cat back flowmaster, intake.
    Nov 2010
    Alberta. Canada
    1,546
    Do you have abs
    Apr 2010
    52
    Re: Help>> breaks not working :(
    Quote Originally Posted by Jester32 View Post
    Do you have abs
    yes
    Nov 2010
    Alberta. Canada
    1,546
    Alot of times you have to perform a bleed procedure with a scan tool. Air gets trapped in the hcu valves and you need a scan tool to activate them.
    Apr 2010
    52
    hmm ok.. well that makes sense. How do i do that? lol
    Apr 2010
    52
    So from im reading online.. i basically need to activate the pump. is there any manual way to do that?
  7. #7
    Nov 2010
    Alberta. Canada
    1,546
    I'm not sure if you give me year make model I can check service info. I work for dodge.
  8. #8
    Apr 2010
    52
    94 grand cherokee all time 4x4 5.2 automatic
    disk up front, dumbs in rear.
    i saw some post on other sites where people says to break hard on gravel to engage abs.. i tried it, abs did kick on, then i came back and bleed brakes again. It did help just a little bit, so i repeated the process twice. But still the same.
  9. #9
    Nov 2010
    Alberta. Canada
    1,546
    Ok. With key off. Pump brakes a bunch of times then open master and crack rf bleeder screw let it drip out with out touching the brakes. Then. Close bleeder pump and repeat on left side. Try to gravity bleed them.
  10. #10
    Nov 2010
    Alberta. Canada
    1,546
    And make sure rear brakes are adjusted proper. That will cause a low pedal.
  11. #11
    Nov 2010
    Alberta. Canada
    1,546
    Make sure master stays full for whole procedure.
  12. #12
    Apr 2010
    52
    Thanks, ill give it a try after work tomorrow and let ya know what happens. About out of daylight for today
  13. #13
    Make sure the front calipers are on the correct side, the bleeder valves should be higher than the banjo bolt.
  14. #14
    Nov 2010
    Alberta. Canada
    1,546
    This is true seen that before. A caliper packaged wrong and installed. Can't bleed air if the bleeder is the lowest point.
  15. #15
    Apr 2010
    52
    I did not think about that.. that very well could be it. As far as the abs, if its working then the air should at least be out of that part right?
  16. #16
    Apr 2010
    52
    Sure enough! they were on the wrong side. Problem solved. Everything is working great now. Thanks for the help, i would have never caught that one.
  17. #17
    Glad you got it figured out. Pretty common mistake when both calipers are pulled off at once.
  1. 4x4 not working
    By Mhulderman in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-10-2011, 05:15 PM
  2. the thing below the tire/wheel, but above the breaks - what is it called?
    By onetwo in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-24-2010, 02:33 PM
  3. '79 CJ problem with breaks! NEED HELP!
    By AdrianM824 in forum Wrangler and CJ
    Last Post: 02-21-2010, 09:57 AM
  4. 4wd isn't working
    By PASmokeater in forum Wrangler and CJ
  5. 4wd not working on '89 YJ, 4.2L, 5 SPD
    By RayOvac in forum Wrangler and CJ
