Thread: 1997 zj
  1. 1997 zj
    I'm preparing to buy a 97 zj with 130K miles very nice interior but it has a leaky rear seal and transfer case. How easy is it to fix these 2 things?
    Mar 2003
    Leonia, NJ
    1,319
    Re: 1997 zj
    What rear seal? Diff over? pinion gear? Transfer can be cracked open and scrape off the old RTV and reapply new. Depending on what rear seal it is might just be more of the same.
    Bought the jeep. The rear main seal behind the engine. It passed smog but the ABS light is on and it's not clicking at all when the key is in the on position. What is the first thing I should check?
    Dec 1999
    Virginia Beach VA
    8,078
    Re: 1997 zj
    Quote Originally Posted by JVjeeper View Post
    Do you mean that it won't start? You mentioned that it passed emissions, so I'd guess it ran at one point.
    I'd take it to the local parts store and ask them to pull any codes off of it. That may tell you why the ABS light is on.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    It runs very strong but I have to get a brake and light inspection which it will fail if the ABS light is on.
    Thanks, I'll try to get the codes pulled.
    My brake light was on when I got my jeep but it went off on it's own. I would start by checking the fluid level and then see what codes it's throwing
  1. 1997 TJ Stalling
    By Gr8tdragon in forum Wrangler and CJ
    Last Post: 08-28-2010, 08:31 PM
  2. 1997 wrangler DRL
    By Team Twisted Off Road in forum Wrangler and CJ
    Last Post: 04-27-2010, 04:48 PM
  3. 1997 wrangler
    By drew32 in forum Wrangler and CJ
    Last Post: 08-05-2009, 11:22 AM
  4. 1997 tj 4wd will not engage... help!
    By lushpupp in forum Wrangler and CJ
    Last Post: 02-27-2007, 08:59 PM
  5. 1997 wrangler
    By mufflerman in forum Items for Sale, Trade, or Give Away
    Last Post: 06-21-2006, 08:11 PM
