my grand cherokee started and then just died now it wont fire im akid and i need HELP
nelson46
i started my 1997 grand cherokee pulled out of my drive way and it just died and now its not firing! any ideas? I need some help quick!:x
Welcome to Jeepz.com
Does the engine turn over when you try to start it?
Does is sound strong, or turn over slowly?
Is anything disconnected in the engine bay? Pay special attention to the ignition system / spark plugs, etc.
Do you have enough gas (I've run out plenty of times...)?
Are you using the correct key, or a valet key?
Describe your problem a bit more and we should be able to help.
the engine turns over there is just no fire.
it turns over strong
i checked all my connections and no spark plugs or wires are disconnected, i also checked all my fuses and all are good
i have 3/4 of a tank of a gas and i am using the correct key
How do i check fuel pressure on this jeep? on my old jeep i could press the fuel pressure regulator and gas would squirt out, can you do this on this jeep?
To test the fuel pressure you'll need to hook a gauge up to the fuel rail.
If you notice low fuel pressure, start by changing the fuel filter
now my jeep will start but it runs on low rpms and if u dont press the gas to keep it running if not it just dies
Is there a check engine lite? Is. The Engine throwing any CODES? If it is --- this can Point us in the right direction . . . Might be the IAC? ---- Also--- what did you have to do to GET it to start?? - JB
