'98 GC rear cargo area leak
ironbutttad
When it rains, I get a small puddle of water on the cargo liner in the rear cargo area. The puddle is centered and about 6-12" or so in from the bottom of the rear hatch.
It's got to be coming from above. The weather seal looks to be intact and in good shape on both the full door and the glass.
There is a small dent near the rear washer/sprayer.
I just noticed this and haven't pulled any panels or lights or put any powder around to try and track it.
I thought I'd check here first and see if anyone had seen this problem.
Any thoughts/ Ideas?
Thanks
id just sit in the hatch and tell someone to spray a hose on it till i found the leak
Rubbers might look good but doesnt mean they are sealing well, why not put a smear of grease etc on them so when its all shut up hopefully there wont e any low areas. It only takes a tiny gap to let in lots of water.
Also ^^^ x2 on the above post before or after.
