front drive shaft
As long as its not an quadra trac. If you can select 2wd. It will be fine
Thanks, that's what I thought.
I've been chasing a noise, vibration, and think its the front drive shaft. I've already replace the rotors, pads, caliber bkts, hubs, and axels. If this doesn't fix it, I am selling the car.
rbelair said:
Wondering same thing about my 99 sport
As long as it is not full time all wheel drive you can drive it with the front drive shaft out. When it is out I wouldnt use your 4wd just in case it messes something up
Sent from my Exhibit using Jeepz
