1. 4.0L timing check - Can I use a normal timing light?
    Can i use just a normal timing light to check and adjust the timing on my 97 cherokee4.0
    Re: 4.0L timing check - Can I use a normal timing light?
    Yes, to check timing, but it's not adjustable. The timing is controlled by the computer.
    So I have to take it to a dealer to have the timing fixed. Or a independent shop with the proper computer
    Feb 2012
    Cincinnati, Ohio
    1,993
    yes sir.
    Quote Originally Posted by USAFJEEPR View Post
    Neither, the timing is adjusted by the Jeep's computer. When the engine is assembled the timing is either spot on or 180* out.
    What is your engine doing that makes you believe the timing is off?
    Well I've had a lot of issues. I bought it super cheap not running. It takes me forever to start it. I usually can't get it to idle. I did get it to idle one day and a code popped up for the cps. So I replace that. Fuel pressure is good. And I pulled my iac motor. It's nasty. So I'm going to replace that. But if that didn't help I was going to check timing. I have replace plugs wires cap and rotor.
  1. Check engine light flashes 12 times and check gage light on
    By crzycicada in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-28-2012, 11:08 AM
  2. Timing Help AMC 360
    By 82CJ7JEEP in forum Wrangler and CJ
    Last Post: 04-30-2011, 11:57 PM
  3. Timing Help ?
    By lovin life in forum Wrangler and CJ
    Last Post: 01-05-2010, 11:43 PM
  4. timing on 4.2l
    By south7069 in forum Wrangler and CJ
    Last Post: 06-08-2009, 11:09 AM
