Thread: Jeep runs ruff
    Jeep runs ruff
    Hi I got a 98 jeep cherokee sport it's lifted 6.5 inches, has fender flairs, and full exhaust system but I'm having this problem when i start it it runs great for awhile until it gets to running temp when I'm driving it and I'm at a dead stop and then take off it will start to lose power and start popping threw the air box then I have to push the gas to the floor for it to go and it gains power back. My buddy put his scanner on it and it said tps sensor and map sensor was faulty but I changed out the tps and it still does it does anyone kno if the map sensor can cause this problem before I spend $70 on a map sensor...... If anyone else has had this problem before and could tell me wat they did to fix it it would be great thanks
  2. Map sensor yes and cps too
    Replaced both of them
    Re: Jeep runs ruff
    That model has problems with developing a short in the wiring harness to the CPS sensor. When the Jeep is idling and running well, move the CPS harness as much as possible and see if you can replicate the stumbling.
  5. You may have a vacuum leak. That will effect timing.
    Also sounds like a dirty fuel filter.
  1. Military Jeep run S.Newengland
    By Rubiconrich in forum Events
    Last Post: 05-23-2010, 08:43 PM
  2. jeeps cold= ruff idle until warm, what gives
    By 288sunny in forum Wrangler and CJ
    Last Post: 12-21-2009, 05:19 PM
  3. Will my Jeep run if I remove my emissions junk?
    By Boze in forum Wrangler and CJ
    Last Post: 03-15-2009, 12:59 AM
  4. Jeep Runs until i put in reverse..
    By Super6XJ in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-03-2008, 04:01 PM
  5. 91 jeep running rough
    By lgbent in forum Wrangler and CJ
    Last Post: 01-29-2007, 06:43 AM
