1995 Grand Cherokee power seat question
Lacey
I need to buy a used power switch or track assembly for my driver seat in my Grand Cherokee. I need to know what years will work in a 1995? Also, if the track is working correctly, can I safely just replace the switch or power unit or is it easier to just replace the whole assembly? Thanks for any help! :)
Hey Lacey ! Welcome to Jeepz.com :welcome: Did a quick search on Rockauto to get a part number and found DS888 and a stock number 4373666 . I also found that DS888 goes from 1993-2004 on grand cherokee and even cross referenced to 2005 dodge Ram series . Apparently , it's a common Chrysler part . Try an internet search of the parts number(s) and see if you can come up with any other applications that may help you to find other vehicles in the wrecking yards that are available in your area . Hope this helps . Best of luck and thanks for your membership at Jeepz.com ! Greg
