help! I need help figuring out what is wrong with my 2002 jeep grand cherokee laredo
howlingwolf23
I recently got my jeep back on the road and had to change the battery and after 2 weeks it won't start after it heats up... I have changed my radiator and water pump to check for cooling problem then I had crank shaft sensor changed then changed spark plugs cuz they were really warn down and it still won't start... the mechanic i have working on it figures I have to change the crank shaft sensor again in case it was blown out again because im not getting any spark from the plugs... and before I changed my battery my stereo worked and after I changed the battery the stereo no longer works?? Any help would be so grateful thanx
