97 GC won't start when cold
dadof5males
1997 Grand Cherokee won't start, but turns over only when cold. Replaced pcv valve elbow because it was cracked. Will start if vacuum line is pulled off the intake. Had mechanic check with scanner, but no codes were found. Vacuum is at 19", fuel pressure at 55 psi, but drops when setting still over 15 minutes. Any ideas?
Idle air control solenoid or map sensor dirty or failing?
Sent from my iPad using Jeepz
