96 ZJ passenger side power issue.
Kabeatty
My 96 grand Cherokee limited has no power locks, power windows, or power mirrors on the passenger side doors. Even the little entrance light on the front passenger door doesn't function. I am fairly certain the issue is an electrical one, but I don't know where to look. I have visually inspected the wiring in both front door boots. And I have checked the fuses. I'm at a loss, any help is appreciated.
Driver door ok - driver controls work on R/S door? or not driver or passenger controls work?
I would look in the door panel.
Can you use a test light and a wiring diagram? We can get you the diagrams....
TIP: before removing door trim panel get the plastic trim push fasteners they often break when removing panel.
dorman products #700-743 get at NAPA
Driver side controls do nothing for those 2 passenger side doors. I can't roll down those 2 windows at all
can you read wiring diagrams and use a test light ? I will add diagrams if your able.
thank God for AC. Have a great 4th
