1. How to bend the end of your tail pipe
    Can't believe it but the new shackles are running into the end of my exhaust so the stock XJ is having it's first clearance issue.
    My best idea is to protect the tank with a welding blanket and heat red hot where I want the bend and then stick a 2ft pry bar in there and see if I can get it to move. I don't have a serious torch so the best heat I'd have available is just propane or this new MAPP gas, which are about the same thing. I'm not sure if plain propane would get hot enough. Can this be done with anything short of an acetylene torch?
    And how close is too close routing it by the gas tank? If I don't bend it down some it'll end up being a bout 2" away.
    Feb 2009
    Dayton Ohio Area
    5,449
    Re: How to bend the end of your tail pipe
    Did you tale it to a muffler shop or at least call one? Costs are many times inexpensive and less stress on you without tools. Bending can end up crimping the pipe.
    Regards,
    JPNinPA
    Sent using TapTalk
    Yeah called the muffler shop closest to me but said they were too busy to deal with it so I came here. But yeah I hear ya. I'll call around to more shops and see what I can figure out.
    a muffler shop can cut the pipe, then expand it and the slide it back over itself after an adjustment.
  5. Re: How to bend the end of your tail pipe
    I used to do quick little adjustments like that for lunch or beer money lol..doesn't take a lot of time but if we were slammed with work I would just tell you to come by near closing time (beer 30) . If you try to do it yourself with a propane torch it will take a lot longer to heat up to the cherry red temp you need it to be and will use a lot more propane..you can expect a small or slight kink in the tail pipe but nothing too hideous and it wont hurt the flow any..you could also try to use a sawzall if you have one and have enough room to fit in there and have someone hold the pipe stable and solid with a huge channel lock so it doesn't bounce around, then buy a turn down (chrome) from an auto parts store if available..
  6. How to bend the end of your tail pipe
    Propane or mapp gas is unlikely to produce the heat you need.
  7. #7
    Feb 2009
    Dayton Ohio Area
    5,449
    Another alternative is electrician or plumbing houses have pipe benders fir conduit or some piping.
    Not all have it
    I shopped around until i found what i liked.
  1. straight pipe
    By 72chokers in forum Wrangler and CJ
    Last Post: 03-28-2013, 10:49 AM
  2. cj-7 exhaust pipe
    By synergy in forum Wrangler and CJ
  3. need help w/ my tail pipe
    By MORGSTER in forum Wrangler and CJ
  4. so i tore my tail pipe hanger again
    By Greencuke in forum Wrangler and CJ
