1. Starting problem 2008 Grand Cherokee
    3 months ago.....then. Month ago...then today....no start. Each time towed to my mechanics, left in lot.....mechanic comes out later ( an hour to 2 hours ) to tow into shop.....starts up. Mechanic checks over everything.....so...if the tow service can't start it at my house...but goes for a ride on the tow truck, then sits....awhile....it starts. Battery ok...Starter ok...computer says all is ok....after it starts.
    Dec 1999
    Virginia Beach VA
    8,058
    Re: Starting problem 2008 Grand Cherokee
    Welcome to Jeepz.com WisconsinMike
    1. If you let the Jeep sit in your driveway, does it eventually come back to life?
    2. When it won't start, what happens?
    3. Do the dash lights come on?
    4. Do you hear a "click" when you turn the key?
    My 2005 Wrangler Build Thread
    Quote Originally Posted by TerryMason View Post
    No coming back to life. When it fails to start....have all lights on dash all outside lights radio etc...no click. Today after posting, put in neutral....started right up.....the tow drivers...who I am getting to know well, have tried this before and it did not start.
    Thanks
    Feb 2009
    Dayton Ohio Area
    5,529
    If it starts in neutral or by moving the shifter near out of park. There is a NSS neutral safety switch on the transmission. It can be cleaned and adjusted.
    As always i will tell you to clean the battery terminals connectors and the opposite ends of the power and grounds. By clean they should be shiny metal surfaces that touch.
    Yrs ago I had a GMC work van with similar symptoms. Usually it would start back up in 10-15 minutes but then it died and wouldn't restart so I called a wrecker. When it got to the shop it started right up. After discussing it with the mechanic he decided to replace the distributor and that fixed the issue! Not saying that is your issue but something to check on.
    As Jim said - it never hurts to clean all your connections!!
    Feb 2009
    Dayton Ohio Area
    5,529
    Quote Originally Posted by mark sr View Post
    As Jim said
    “You don't tug on superman's cape.
    You don't spit into the wind.
    You don't pull the mask off that old lone ranger.
    And you don't mess around with Jim”
    Or Not Jim. 🤫
  1. F/S 2008 Jeep Grand Cherokee Overland 5.7L Hemi 4x4 -- 58k miles -- $21,000
    By smloboda in forum Items for Sale, Trade, or Give Away
    Last Post: 03-04-2014, 02:51 PM
  2. 2008 Jeep Grand Cherokee Power Window will not go up or down
    By Jeeperscreeper in forum Jeep Electronics and Audio
    Last Post: 01-26-2013, 11:09 PM
  3. ForSale: 2008 Jeep Grand Cherokee Overland 4x4 / 64,500 Miles (21,000)
    By DudeFromPittsburgh in forum Items for Sale, Trade, or Give Away
    Last Post: 05-29-2012, 01:44 AM
  4. 93 Grand Cherokee V8 Starting problem
    By hcarcella in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-28-2005, 12:58 PM
