Jeep Grand Cherokee Laredo 2001 4.0 02sensor heater codes.
dlmrun2002
So after much sitting in my driveway after a failed Crank sensor, a leaking gas tank and rusted out skid plate for the gas tank, I got the ugly monster running ok. But I'm do for a NY inspection and I am getting codes related to the 02 sensors heaters. It's on all four 02 sensors and it is on the heaters side( Sorry cleared codes and didn't grab numbers). Any circuit or fuse carrying this power supply for the heaters? Thanks.
dlm ny country
Yes check your fuses. Check your battery too. Its unlikely all four go at once but a weak battery can cause wierd codes.
If you replace use OEM which is NTK brand.
Thanks. With the vehicle sitting for a while (at least 4 months), the battery has taken a turn for the worst. It doesn't hold good voltage over a few days of idle parking.
If you have a trickle charger you could possibly save the battery. Charging in an on a day and off a day may reverse the scaling on the plates. However If the scale is crystallized you are done.
Regards,
JPNinPA
Sent using TapTalk
I have a trickle charger for my 1974 BMW. I can swap it over to the Jeep for a few days. My regular battery charger has a setting for 2 amps also. Will give it a go.
dlm ny country
So Jeep has been getting some use but not much (don't want to get a no inspection ticket).. It still is throwing 02 heaters codes, sometimes all 4 but usually P0138, bank 1 sensor 2. It will throw it too, after a fresh start if I clear the codes, usually by itself with no other codes. Jeep is running fine otherwise(minus a Speedometer that just started cutting out sometimes). Not sure if the one sensor (Bank 1 sensor2) could be what is throwing the whole thing off. Hate to buy a sensor and then find out that wasn't the deal. Looking for input. Thanks.
dlm ny country
You have inspected the wiring? Do you have exhaust leaks?
Check the fuse and relay below. Not sure 01 is the same but worth a shotThe next step would be to hook up a scanner that you could see the O2 switching. Or pull an O2
Regards,
JPNinPA
Sent using TapTalk
Thanks so much JPNinPA. I will give it a go when I get a chance. This weekend, I stopped clearing codes with the MIL light on. I was getting all these mixed 02 heater related codes. Funny , today I get in the WJ to go home and MIL light was off. So I checked when I got home and there were several various 02 heater related codes in memory but no MIL Light. I left it alone for now. It feels like a wire connection of some type. All the monitors haven't cleared so it still won't pass inspection.
dlm ny country
You figure this out?
Have you corrected the battery issue?
Clean the engine ground.both sides.
